查看: 5076|回復: 3
Akzo-Nobel's technology
發表于 2007-7-3 20:47:11 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
[b]Akzo-Nobel's technology for FRP[/b]
[b]Interpon Impress®[b][/b][/b]
Due to its benefits in cost-saving & environment-friendly, Powder Coating for reinforced plastics has been a hot topic. Akzo-Nobel, the technical leader of the world coating, and also the world’s largest supplier in powder coating, has developed a new product traded as Impress.
Impress is the trade name for an in-mold powder coating process used as either a primer or a finish coat for compression molded reinforced plastic substrates including SMC、TMC、BMC & FRP.
[b]Features:[/b]
    Fast free radical cure mechanism (no additional cure time in the mold)
    High cross-link density (high hardness and chemical resistance)
    Internal mold release  (no need to spray on mold release agent)
    Oxygen inhibited cure (enables chemical co-reaction with substrate)
    Impress finish matches mold gloss, texture,
[b]Process[/b]
    Apply powder to hot mold, 100-200 microns
    Powder fuses, melts, flows, gels, 10-30 secs
    Unreacted FRP into mold cavity
    As press closes, substrate flows under heat and pressure to fill cavity, < 5 secs
    Coating remains intact against mold surface
    Substrate and coating co-react, 1-5 minutes
    Coating releases as cured part is removed
[b]Benefits [/b]
    Product durability and performance
    Isolate fibers and pores from the surface
    Reduce solvent penetration
    Improved weathering possible
    Homogeneous surface
    Moving value to the surface
Application
    Heavy truck components&
    Stadium seating
    ADA Safety Tile
    Racing/motorcycle helmets
    Recreational boats & Jet Skis
    Sanitaryware & showers
    Bus Seats/Railcar seats
Interpon Impress®
玻璃鋼表面使用粉末涂料涂裝,因其具有環保優越性正受到人們越來越多的歡迎,也成為粉末涂料廠商研發的熱點,阿克蘇•諾貝爾作為全球涂料技術的領導者,是塑料及復合材料(如:玻璃鋼)涂裝用粉末涂料的主要供應商。
Interpon Impress 是塑料及復合材料(如:玻璃鋼)涂裝用粉末涂料,用于模壓成型涂裝的底漆或面漆。涂裝底材主要是表面粗糙(內有孔穴,玻纖等)的TMC、SMC、BMC&RTP,采用模壓成型的方法使得表面一次涂裝平整。
[b]粉末涂裝特征[/b]
    激烈快速的固化機制
    無需太多的模內固化時間
    高交聯密度
    高硬度和好的耐化學性能
    內部脫模
    無需噴涂脫模劑
    氧氣內嵌固化
    使粉末與底材發生化學反應
    Impress表面狀態與模具吻合較好(光澤,紋理等)
[b]
粉末涂裝步驟:[/b]
    將粉末噴涂于預熱的模具表面,(100-200 micron)
    粉末熔融、流平、膠化 (10-30 秒)
    未處理的玻璃鋼置于模腔中
    隨著模具的合閉,底材在熱壓作用下填滿模腔
    涂層相對于模具表面保持完整
    底材和涂層反應 (1-5分鐘)
    固化脫模
[b]粉末涂裝優點[/b]
    產品的性能和耐久性
    涂層將玻纖、小孔覆蓋
    提高耐溶劑性能
    改良耐候性
    表面平整,光亮
    為客戶創造價值
[b]應用領域[/b]
    重型卡車及農用機械組件
    戶外運動場座椅
    地鐵安全防條
    安全帽
    游艇&摩托艇
    家具及室內衛浴用品
    交通運輸業&汽車組件
Ben Wu    吳國斌
Akzo Nobel Powder Coatings
Tel:  +86-755-27419948
Fax: +86-755-29936451
Mobile: +86 1382-522-6242
E-mail: [email]ben.wu@interpon.com[/email]
Website: [url]www.akzo-nobel.com[/url] or [url]www.interpon.com[/url]
Address: Luotian Road, Yanchuan Village, Songgang Town Bao An District, Shenzhen, P.R. China
發表于 2007-7-4 09:24:57 | 只看該作者
呵,現在不冒充經銷商了
你說 你是經銷商,要買模內涂層粉末嗎? FERRO?
發表于 2007-7-9 20:37:33 | 只看該作者
你是經銷商嗎?
發表于 2007-7-10 10:38:23 | 只看該作者
冒充經銷商
[quote]引用第2樓everywhere于2007-07-09 20:37發表的  :
你是經銷商嗎?[/quote]
我是說AKZO-NOBEL有2個人,1個是深圳的冒充經銷商,另1個是河北的冒充用戶,向我們尋求模內涂層粉末的價格。我們有PIMC模內涂層的產品/樣品
GMT+8, 2026-5-27 16:01 , Processed in 1.123829 second(s), 20 queries .
