查看: 4893|回復: 0
Vacuum Infusion - The Equipment and Process of
發表于 2006-12-20 11:34:02 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
Resin Infusion
Introduction
The Vacuum Infusion Process (VIP) is a technique that uses vacuum pressure to drive resin into
a laminate. Materials are laid dry into the mold and the vacuum is applied before resin is
introduced. Once a complete vacuum is achieved, resin is literally sucked into the laminate via
carefully placed tubing. This process is aided by an assortment of supplies and materials.
In a typical hand lay-up, reinforcements are laid into a mold and manually wet out using brushes,
rollers, or through other means. An improvement on that method is to use a vacuum bag to suck
excess resin out of the laminate. Vacuum bagging greatly improves the fiber-to-resin ratio, and
results in a stronger and lighter product. If you are unfamiliar with vacuum bagging, we
recommend reading our brochure, Vacuum Bagging Equipment and Techniques for Room-Temp
Applications, as VIP requires experience in this area and uses many of the same principles.
Vacuum infusion builds upon these principles, providing further improvements to the lamination
process.
Benefits of Vacuum Infusion
Vacuum infusion provides a number of improvements over traditionally vacuum bagged parts.
These benefits include:
• Better fiber-to-resin ratio
• Less wasted resin
• Very consistent resin usage
• Unlimited set-up time
• Cleaner
VIP offers a better fiber-to-resin ratio than vacuum bagging. A typical hand lay-up usually
results in excess of 100% fabric weight by resin. Resin alone is very brittle, so any excess will
actually weaken the part. Vacuum bagging can reduce this number significantly; however, it is still
not ideal and can lead to additional problems.
While vacuum bagging certainly improves on the hand lay-up, there is still a hand lay-up involved.
Because of this, the laminate will always begin in an oversaturated state. Vacuum pressure will
remove much of the excess resin, but the amount removed still depends on a variety of variables
including reinforcement, resin, time factors, and others.
Vacuum infusion takes a different approach, in that a vacuum is drawn while the materials are still
dry. From that point, resin is infused using vacuum pressure. Rather than starting with excess
and drawing resin out, VIP starts with none and pushes resin in. Ideally, any excess resin that is
introduced will eventually be sucked out into the vacuum line. As a result, only the minimum
amount of resin is introduced. This lowers weight, increases strength, and maximizes the
properties of fiber and resin. Parts constructed using VIP can approach prepreg levels of resin
content.
Due to the nature of VIP, resin usage becomes very predictable. While a standard lay-up varies
in resin content due to the human variable, VIP is remarkably consistent. Even when creating a
large product, resin usage will be predictably similar upon repeated attempts. This results in
less wasted resin, and more importantly, less wasted money.
Pg. 2 of 14
Vacuum infusion provides another valuable benefit: time. A frequent problem that can arise
in vacuum bagging is the time factor. Many resins have a pot-life of about 30 minutes, though
there are certainly some (such as our System 2000 Epoxy) that offer work times of up to 2 hours.
Even so, that time limit is extremely critical in vacuum bagging applications. Large projects can
easily approach the 2 hour mark, and even small, seemingly simple projects can quickly turn
frantic when a pesky leak in the vacuum seal cannot be found. Also, depending on when the bag
is applied, the amount of resin removed can vary from part to part.
Vacuum infusion, however, offers unlimited set-up time. Because the vacuum is applied while
reinforcements are still dry, there is no resin clock to work against. After the bag is applied, leaks
can be patiently sought out. If something is not sitting properly, simply release vacuum and
readjust. No time constraints are introduced until it is decided that it is time to infuse the resin.
Until that moment, changes can be made again and again.
Finally, vacuum infusion is a much cleaner process. There are no brushes or rollers, and
therefore no splashing or spattering. No one will be required to hover over an open mold,
saturating a laminate by hand, trying not to drip on himself. In addition, there are less resin fumes
to contend with. Because the only fumes radiate from the resin reservoir, they are somewhat
containable. VIP provides a cleaner, safer, and friendlier work environment, though it is still
important to work in a well ventilated area and wear a respirator and other appropriate safety
equipment.
Potential Pitfalls
Like any laminating process, VIP is not without its drawbacks. When attempting infusion for the
first time, it is important to keep the following ideas in mind.
• Complicated set-up
• Easy to ruin a part
• Trial and error
Though set-up is time-limit free, it is somewhat more complicated. Vacuum bagging requires the
placement of only the vacuum tubing. Vacuum infusion requires not only vacuum tubes but resin
inlets as well, not to mention in-bag extensions of these tubes. Placement of these vacuum and
resin lines varies from part to part, and there is no one way to set them up. These considerations
must be evaluated prior to lay-up, or else the part could be ruined.
This leads into the next pitfall; it is very easy to destroy a part. Typically, once infusion begins,
there is little that can be done to correct any errors. For example, if a leak were to occur, even
the smallest amount of air introduced could be potentially fatal to a part. It would probably result
in resin pooling, undersaturation, or even a complete stoppage of resin flow. Though there are
certainly some cases where problems can be corrected, it should not be expected. The best
protection from disaster is careful planning.
Due to the complexity and ease of error, VIP should be viewed as a trial-and-error process.
The best mindset to have when attempting vacuum infusion for the first time is that a few parts (or
more than a few) will be ruined before getting it right. The trick is to carefully document each
attempt in order to learn from each trial. Keep track of the resin flow rates. Determine where the
resin is reluctant to go and find a way to get it there. Even the smallest modifications can yield
drastically different results. Practice with small quantities and inexpensive materials before
undertaking full-scale projects. The key is learning from mistakes. This is especially the case
when working with larger projects requiring multiple vacuum and resin lines. In a manufacturing
environment, it is recommended that at least 6 months are set aside for testing and preparation.
Pg. 3 of 14
VIP Set-up and Equipment
When preparing to experiment with infusion, it is important to understand some general concepts
about how materials are used and arranged. Keep in mind that every project is unique and this
guide is not intended to provide the only available options. We will discuss some variations later.
First, the general sequence of events that comprises vacuum infusion is illustrated in the following
diagram.
For the purpose of this brochure, we will be focusing on one general set-up idea with the notion
that resin will be infused into a center point in the laminate. From there, resin will be pulled
outward via vacuum pressure. The final arrangement of materials should look something like
this.
Note: For the purposes of this diagram, the vacuum bag itself is not shown
Pg. 4 of 14
With this final goal in mind, let’s take a closer, step-by-step look at what materials are used and
how to go about using them.
Step 1 The Mold
Prepare your mold
Select your reinforcement
Select your flow media and/or core material
Step 2 Resin and Vacuum Lines
Select your resin feed lines
Select your vacuum lines
Step 3 Vacuum Bag
Build your vacuum bag
Allow for prohibiting resin from entering the vacuum
Step 4 Vacuum Pump
Attach the pump
Ensure proper vacuum
Step 5 Prepare for Infusion
Select your resin
Resin bucket set-up
Step 6 Resin Infusion
Catalyze your resin and allow it to start infusing
Clamp off resin line
Step 7 Experiment and Test for Improvement
Helpful supplies for vacuum infusion
Typical variations in set-up
Step 1 The Mold
Prepare your mold
Like any lamination process, a good quality mold is required for vacuum infusion. The mold
should be rigid and have a high-gloss finish. Ideally, this mold will have flange of at least 6 inches
to be used for the placement of sealant tape and spiral tubing. After the mold is properly cleaned,
apply your ordinary, preferred mold release agent. Unique mold releases are not required for
resin infusion.
Pg. 5 of 14
Choosing reinforcement is an important decision for any laminate, but there are additional
considerations when choosing one for infusion. While all fabrics will potentially infuse, different
materials and weave styles can severely alter resin flow rates. The following offers some general
guidelines for choosing materials, though individual experiences may vary.
Fiberglass is the most frequently used reinforcement in vacuum infusion. Most fiberglass fabrics
offer high permeability, allowing resin to easily flow through. In general, looser weaves tend to
infuse better, as there is less crimping of strands.
When using a non-woven mat, continuous strand mat will offer superior infusion over a choppedstrand.
While both offer high permeability, the binder in chopped strand mat somewhat hinders
resin flow. Continuous strand mat (#251) will avoid this problem.
Knit fabrics are frequently used for infusion due to their construction. These fabrics are not
woven, but rather are knit together to avoid crimping caused by weaves. The #293 Knit Fabric is
18 oz. fiberglass roving knit to a 1.5 oz. chopped strand mat. This material not only boosts resin
flow, but also adds strength and bulk very quickly.
Carbon Fiber (Graphite) and Kevlar® reinforcements can also be used in vacuum infusion,
though they tend to infuse more slowly. To counteract this, the addition of flow media was found
to greatly increase infusion rates and create successful parts using both #1110 Vinyl Ester and
#2000 Epoxy resins. It is a good idea to experiment with these materials beforehand in order to
properly gauge flows rates.
When working with molds of a more complex shape, dry reinforcement may not readily sit flat.
Super 77™ Spray Adhesive (#1404) is the recommended remedy for this problem. Spray a light
layer of adhesive on the mold surface and lay down the reinforcement. This should provide
enough adhesion to hold the materials in place. When used moderately, Super 77™ will not
interfere with the resin infusion or curing process.
Pg. 6 of 14
Flow Media
A concept unique to vacuum infusion is the idea of flow media. In VIP, resin enters the laminate
at a fixed point (or points) and must be directed. Resin will always travel in the path of least
resistance. Unfortunately, many reinforcements can provide a great deal of resistance that can
prevent resin flow. Aiding the flow of resin is the job of flow media.
Although it is possible to infuse resin into a reinforcement without the addition of flow media, it is
rarely successful. The flow media is typically laid as a single layer between layers of
reinforcement to provide an easy flow conduit for resin. This material ultimately becomes part of
the laminate.
Flow media comes in several styles.
• EnkaFusion Nylon Matting (#1401) provides the fastest infusion times. Constructed of
randomly oriented, entangled nylon filaments, this matting can typically move resin as
fast it can be fed.
• Lantor Soric® XF (#1409) provides maximum conformability. This material is used as
both a bulker and flow media. It has hexagonal flow channels that quickly move resin
throughout the laminate, while simultaneously adding thickness. Laminates incorporating
Soric® can typically experience 35% less resin retention than all glass laminates.
Though used as a core, Lantor Soric® does not provide any significant structural
properties.
• DIVINYMAT Sandwich Core (#1024) serves as both a flow media and structural core.
This material is similar to traditional vinyl foam cores, but includes grooves, perforations,
and scores in the core material to help resin traverse the laminate while simultaneously
adding strength and rigidity. Additionally, this material is on a scrim backing to aid
conformability. (Traditional, closed-cell cores are not recommended as they tend to pool
resin rather than aid its flow.)
Before the vacuum bag is closed, careful consideration must be taken in order to set up resin and
vacuum lines
Select and install your resin feed lines
Resin will be fed from a standing source (usually a bucket.) The line for getting the resin into the
laminate will have to be installed before closing the bag. Although the same tubing that is used
for applying vacuum is fine for getting the resin to the bag, after the resin is being directed
through the laminate there are some materials unique to VIP which can help direct the resin flow.
• EnkaFusion Filter Jacket (#1400) is used in nearly all VIP projects. This material will be
used on top of the laminate and removed from the laminate when pulling the part from
the mold. It will also provide the removable material which can be used for anchoring
your T-fittings which will connect your resin and vacuum lines.
Pg. 7 of 14
EnkaFusion Filter Jacket is a 4” wide resin flow channel which is typically laid out over
the length of the laminate. It is similar to the nylon matting except that it’s narrower and
is contained within a fabric “sock.” The design of this “sock” holds resin until the entire
length is filled. At that point, resin begins to flow outward through the sock and into the
laminate, providing consistent flow rates across a long span. This style of EnkaFusion is
particularly useful for resin feed lines. When used as a surface media, be sure to place
peel ply beneath the Filter Jacket. Otherwise, it will permanently attach itself to the
laminate.
• Spiral tubing (#1403) sometimes called spiral wrap, is a plastic ribbon that is coiled into a
tube shape. Due to its construction, air or resin can enter or leave the walls of the tube
throughout its entire length. This property makes spiral tubing ideal for in-bag vacuum
lines or resin feed lines. When used as a feed line, resin will quickly travel through the
tube, but simultaneously seep out along the way. This allows quick wet-out of a long
stretch within the laminate. Be sure to wrap spiral tubing in peel ply for easy removal.
This diagram shows the addition of EnkaFusion Filter Jacket, which will be used as a resin feed
line.
In addition to the feed line, a smaller piece of EnkaFusion Filter Jacket is placed on top as an
anchor for the T-Fitting which will be the connector for the resin feed line. It is necessary to lock
the T-Fitting into place to prevent shifting and ensure a steady flow rate. Cut a slit in the top layer
for the fitting to poke through. Figure 1 illustrates the three pieces involved, while figure 2 shows
the finished sandwich.
Pg. 8 of 14
Select and install your vacuum lines
In traditional vacuum bagging, a Breather/Bleeder material is typically used to both absorb excess
resin and drive vacuum throughout the laminate. Breather/Bleeder is typically not used in resin
infusion.
Instead, in VIP, the vacuum lines are extended within the sealed bag. Spiral tubing is ideal for
this purpose. In order to achieve complete infusion, resin must be pulled to all corners of the
laminate. Because the standard set-up infuses into the center of the laminate, spiral tubing would
usually be placed around the flange. Once again, spiral tubing should always be wrapped in
peel ply.
When using spiral tubing, it may have a tendency to straighten out or not stay where you want it.
The simplest way to counteract this is to use small pieces of sealant tape. Just ball it up, stick it
to the tubing, and then stick it on the mold.
Step 3 Vacuum Bag and Attach Your Resin Line
Once the dry materials are in place, it is time to build the vacuum bag. The bag should be tight,
but still allow plenty of room for all the materials including networks of tubing. Too much or too
little bag can result in resin pooling or improper infusion.
Once the bag itself is built, attach tubing for the resin and vacuum lines. Be very careful when
making cuts through the bag for these tubes. It is frequently these connections that spring leaks.
Before the pump is switched on, it is important to clamp off the resin line. Because the
vacuum is drawn before the introduction of resin, the resin tube will act as a temporary “leak” that
Pg. 9 of 14
must be sealed off. Simply clamp off this line by creasing the tube and attaching a #1605-A Flow
Regulator to hold it in place.
Resin Trap
One key piece of equipment that is important to understand is the #1500-A Resin Trap. A resin
trap is an airtight container placed within the vacuum tubing circuit between the laminate and the
pump to catch any excess resin before it can enter and destroy the vacuum pump. When set up
properly, the vacuum tubing will flow out of the laminate and connect directly to the resin trap. A
separate tube will then leave the resin trap and connect to the vacuum pump.
During VIP, vacuum pressure is being used to draw resin into the laminate. In many cases, resin
will flow completely through portions of the laminate while still filling dry spots in another. This is
normal and is no cause for alarm except that resin will frequently enter the vacuum line while
continuing to infuse resin.
With a resin trap, all excess resin will be collected in the trap, while air is still allowed to flow back
to the pump. If the part is large and significant resin flow into the vacuum line is expected, any
number of resin traps may be placed in sequence. As soon as one is filled, the resin will overflow
into the next one.
Note: Before using a resin trap, wax the inside of the tank with mold release wax to ensure easy
removal of the hardened resin.
Step 4 Vacuum Pump
Attach the pump
Once all the components are in place, it is time to attach the vacuum pump itself. Because resin
is infused through vacuum pressure, it is quite beneficial to have a stronger pump. In general, a
stronger pump will help expedite infusion.
Once attached, switch the vacuum on. As in any vacuum bagging application, leaks pose the
biggest problem. Even the smallest leak can greatly hinder performance or even completely ruin
a part. Because VIP offers unlimited time to seek out these leaks, considerable effort should be
made to find them all. Even so, there are frequently small leaks that are seemingly impossible to
discover. There are some tools that can greatly aid this process. One handy tool is a #1503-A
Ultrasonic Leak Detector. This small handheld tool is designed to detect ultrasonic frequencies,
while simultaneously screening out audible noise. Wearing the supplied headphones, leaks are
easily heard, while an LED display indicates leak strength. Because audible noise is screened
out, this detector can even be used in a noisy shop environment.
For those on a tighter budget, a simple stethoscope can also be used to detect leaks. Though it
won’t provide the precision that an ultrasonic detector uses, a #1504-A Stethoscope will amplify
leaks and provide a helpful aid at a minimal cost.
Pg. 10 of 14
Select your resin
Resin choice is another key aspect of VIP. There is a common misconception that a special
“infusion resin” is required. This is simply not the case. Any resin can actually be used for
infusion, though there are some general guidelines that should be considered when making a
decision. One important piece of information that should be examined is the resin viscosity.
Typically, lower viscosity will aid infusion, as it allows easier permeation of the reinforcement.
This is not to say that higher viscosity resins will not work, but they may require more careful
planning, more resin lines, and more flow media.
Vinyl Ester is the most frequently used resin for vacuum infusion. At a viscosity of 275
centepoise, our #1110 Vinyl Ester is very well suited for this process. In fact, this is the same
resin that is often called “infusion resin” by other vendors.
Polyester resins such as #77 Molding Resin and #90 Isophthalic provide a viscosity of about 475
centepoise and will also infuse quite readily.
System 2000 Epoxy offers a viscosity of 900-975 centepoise (depending on hardener choices),
and therefore will tend to infuse a bit slower. However, don’t let that be a deterrent. High quality
VIP parts were successfully created using Systems 2000 Epoxy and a variety of reinforcements.
Because this resin can have a longer pot life, slower infusion times are not always a problem.
Set-up considerations may include more feed lines or additional flow media.
Resin Bucket Set-up
Because no brushes or rollers are used in the transfer of resin,
some steps must be completed to ensure that the resin line
stays in the bucket, as any air entering the line could be fatal
to a project. These tools include the bucket itself, a resin line
holder, zip-strips, and a spring clamp. The resin line holder
is basically a length of rigid material that is attached to the
resin tubing via the zip-strips. Once attached, this ensures
that the resin tubing stays fixed in a straight line. This
eliminates the tube’s natural tendency to twist and curl. It is
also helpful to cut the end of the tubing at an angle.
Otherwise, the tube could potentially vacuum seal itself to the
base of the bucket, preventing the flow of resin. Once
attached to the holder, the line is clamped in place to the
bucket. The resulting assembly should ensure that the resin
line will stay exactly where it should be.
Catalyze resin and allow it to infuse
Once everything is in place and ready to go, mix up the resin. Double check that the resin bucket
assembly is firmly in place so the tube will not leave the bucket. Once this is satisfactory, remove
the flow regulator to unclamp the resin inlet. Resin should quickly be sucked through the tube
and into the laminate.
Pg. 11 of 14
Once resin reaches the laminate, the resin feed line will quickly fill up. Once full, the resin will
begin to expand outward into the reinforcement. The rate of infusion depends upon many
variables, but the resin should be visibly moving. Allow this to continue until the entire laminate is
saturated.
Once the laminate is completely wet out, there is no need for further resin to enter. If the bucket
were to be sucked dry, then destructive air bubbles would enter. To prevent this, the resin line
should be clamped off once it’s no longer needed. This is accomplished the same way it was
before resin was introduced; crease the tube and attach a Flow Regulator. While performing this
task, it is crucial that it be done carefully and without significant force that could potentially spring
a new leak.
Once the resin line is clamped off, the infusion is complete. However, it is still not time to turn off
the vacuum pump. Keep the pump running to maintain constant vacuum pressure until the resin
has sufficiently gelled. Otherwise, air could be introduced prematurely.
Helpful Supplies for Vacuum Infusion
Like any lamination method, there are certain supplies for VIP that are not required but offer
significant advantages. These items can save time and help gather useful data for further
experimentation.
Thermal Gun
A useful piece of information during infusion is the resin temperature. The temperature tells you
when the resin is beginning to cure, when the laminate has achieved peak exotherm, and when
the laminate has returned to room temperature.
To determine the temperature, #1502-A Thermal Gun can be used. This simple device can be
pointed at an area and will instantly give a temperature reading. It is often useful to regularly
check a number of areas including the resin bucket, the resin inlet, and the outer portions of the
resin flow in order to keep tabs on its progress.
Stop Watch and Marker
While infusing, and especially when practicing with VIP, it is a good idea to monitor resin flow
rates and resin flow paths over time. This can easily be done with a simple stop watch and a
marker. Start the timer when resin is first introduced into the laminate. At regular intervals, mark
the bag with the resin’s current position. This piece of information can be especially helpful upon
further infusion attempts, determining if small changes in set-up have any noticeable effect.
Typical Variations in Set-up
With an understanding of basic theory and supplies, it is time to discuss variations of materials
within the mold. Keep in mind there is no one correct way to do this; however, the general idea is
the same regardless of arrangement choices.
Pg. 12 of 14
When choosing material arrangements, it is helpful to understand why resin travels the way it
does. When a vacuum is pulled, all air is removed from the laminate, creating open spaces of
complete vacuum. This causes pressure to be placed on the laminate. Naturally, this pressure
will want to be relieved by refilling the open spaces. In VIP, resin will provide this relief. There is
a common misconception that the vacuum pump is actually sucking resin into the part. In
actuality, it is the vacuum pressure that is doing the work. Once a vacuum is achieved, the pump
itself can theoretically be clamped off and removed from the equation (though this is not
recommended). Infusion will still occur.
In order to create an even resin front that will wet-out the entire laminate, keep these two resin
flow characteristics in mind.
• Resin wants to fill open spaces created by the vacuum.
• Resin wants to take the path of least resistance.
Utilizing these two concepts, it is possible to manipulate resin across an entire laminate with as
little as one resin inlet and one vacuum outlet. The trick is placing in-bag extensions of these
lines in order to create a uniform resin front. The following figures show how this is done.
In figure 1, resin and vacuum lines are placed without the addition of any in-bag extensions. As a
result, resin will basically travel from one point to the other. However, the majority of the laminate
will remain untouched, and therefore ruined.
In figure 2, resin and vacuum lines are extended. Vacuum line extensions can be made with
spiral tubing, while resin feed line extensions can use either spiral tubing or EnkaFusion Filter
Jacket. In this example, resin will move very quickly through the gray areas. When resin is first
infused, the feed line extension will fill very quickly. Once this line is full, resin will attempt to
reach the nearest possible vacuum line. Because the vacuum line has been extended as well,
the nearest vacuum point will be directly across the laminate. As noted by the resin path arrows,
the entire lay-up will be infused.
General Reminders
Regardless of any particular arrangement of materials, there are a few items that are important to
note.
• Be sure to include a Resin trap in the vacuum line between the mold and the vacuum
pump if there is any possibility that resin can enter the vacuum line while still infusing.
Pg. 13 of 14
• Any material that will be later removed (such as surface flow media or spiral tubing)
should be placed on peel ply. Otherwise, it will be infused into the part.
A Common Variation
In the following example, spiral tubing is used for both the resin feed and the vacuum line. Resin
will enter on one side and fill the length of the tubing very quickly. At that point, resin will begin to
flow across the laminate. While this approach is simpler to set up, the resin will need to travel
across a longer distance. Depending on what materials and equipment are used, this distance
becomes a significant factor. However, on the up-side, the inside surface texture of the finished
part will be consistent.
Larger Projects
Now that the theory of infusion is understood, it is very easy to expand on these concepts in order
to apply them to larger projects. As resin travels away from the feed line, it will encounter more
resistance, ultimately slowing down. To combat this, large projects will require multiple resin and
vacuum lines. In general, resin lines should not be more than 30-36” apart under ideal
conditions. However, when using less permeable materials or higher viscosity resins, this
number may need to be reduced. It is important to experiment with the specific material set
before attempting to create a large project.
Conclusion
Vacuum infusion can appear to be a daunting endeavor, but it doesn’t have to be. Experiment
with different materials and arrangements, as small changes can create significantly different
Pg. 14 of 14
outcomes. Though the first few attempts may be unsuccessful, once the basics are learned,
infusion will quickly become second nature.
A Place to Start
We created our #590-A Vacuum Infusion Trial Kit as a means of familiarizing someone with the
materials that are unique to vacuum infusion. We strongly suggest significant experience with
both vacuum bagging and room temperature molding before tackling resin infusion.
This kit contains enough material to build 3 infusion trial projects up to 24” x 13” each. After
completing these 3 “practice” laminates you will be familiar with EnkaFusion Nylon Matting,
Lantor Soric, EnkaFusion Filter Jacket and Divinymat Sandwich Core. You will be able to judge
the differences in resin travel and conformability as suits your future infusion applications.
Additionally, you will be able to install your vacuum and resin lines and get some experience
controlling your resin bucket and resin flow.
This kit contains:
#505-A Resin Bucket 1 Gallon (x3) #1605-A Flow Regulator (x2)
#512-B Resin Line Holder (x3) #1606-A Spring Clamp
#893 Vacuum Tubing 5’pieces (x3) #906-A T-Fittings (x6)
#1601 Zip Strips (x6) #1400 Filter Jacket 18” (x3)
#1400 Filter Jacket 5” (x3) #1403 Spiral Tubing 5’ pieces (x3)
#582 Peel Ply 5’x5” pieces (x3) #582 Peel Ply 20”x5” pieces (x3)
#1024 DIVINYMAT® 24”x16” #1409 Lantor Soric® 24”x16.37”
#1401 Nylon Matting 24”x13” Instruction Sheet
In order to use the kit, you will need your own vacuum pump, bagging materials and vacuum
tubing to attach to the bag. Also, you will need to supply your own resin and reinforcement.
Last, you will need a mold that will require a laminate no larger than 24” x 13” that also has a
relatively large flange.
This kit will supply everything you need for:
One laminate using EnkaFusion Nylon Matting as a Flow Media
One laminate using Lantor Soric® as a Flow Media
One laminate using Divinymat® Sandwich Core as a Flow Media
It includes all of the supplies for resin bucket setup and resin lines, EnkaFusion Filter Jacket,
spiral tubing vacuum extensions, and enough peel ply to handle 3 jobs this size.
If you can vacuum bag, you can infuse resin. The objective of this kit is to help you make
informed decisions about choosing your flow media, placing and using spiral tubing and designing
successful experiments for your own projects in the future. After completing these trial projects,
you will be confident in planning your future flow media and resin line set up. You will be familiar
with all of the terms used in this brochure and hopefully, will be able to reduce the learning curve
and costs associated with the trial and error of successful vacuum infusion!
GMT+8, 2026-5-27 15:53 , Processed in 1.141176 second(s), 19 queries .
