只需一步,快速開(kāi)始
查看: 3085|回復(fù): 0
求氣瓶,壓力為300B,誰(shuí)能提供盡快聯(lián)系!
發(fā)表于 2006-12-18 15:46:01 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
We would like to take the opportunity to introduce ourselves as regular importer & indentor of CNG NGV Cylinder & one of the top 2 business concern in our country engaged CNG Cylinder, CNG Filling Station Equipments & related Alternate fueling equipment business. Our current requirements are following below:
Description: Seamless Steel (CrMoly) Make Type - I & Hoop Wraped Glass Fiber make with steel liner Type - II CNG NGV On Board Cylinder without cap & Neckring, Neckthread 1" & Inlet Thread BS-341-1" std.
Approved Std.: ISO:11439 or NZ:5454 or ISO:4705 or DOT3AA
Working Pressure: 200 Bar     Test Pressure: 300 Bar
Cylinder Bottom: Convex type
Type - I Cylinder size/capacity:
1). 60 W/L Outside dia between 316mm to 325mm
2). 80 W/L Outside dia between 323mm to 356mm
3). 90 W/L Outside dia 356mm
Type - II Cylinder size/capacity:
1). 60 W/L Glass fiber OD 325mm & Composite Cylinder Cyl. OD 340mm
2). 80 W/L Glass Fiber OD 325mm & Composite Cylinder OD 340mm
3). 90 W/L Glass fiber OD 342mm & Cylinder maximum allowed length 1210mm
Certificate: Manufacturer alongwith 3rd Party inspection company Test Certificate.
Because of a regular importer of CNG Cylinder, we have the clear idea about the current International Market Price of CNG NGV Type-I & Type-II Cylinder & always updating ourselves.
In respect of above mentioned, you are requesting to send your best introductory price offer with Cylinder Technical Specs. including length, weight & other relevent information, approved Technical Drawing,  copy of Cylinder catalog/brochure & company profile as soon as possible.
We are waiting for your necessary feedback with professional proposal within short period.
Best Regards,
