查看: 3921|回復: 1
[求助] 老外求購的一些拉擠產品,做拉擠進來看看!
發表于 2014-6-30 18:23:56 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
CABLE TRAY   600MM X 50MMX2400MM =600m
CABLE TRAY  150MM X 50MMX2400MM =2400m
G.I. THREADED ROD 10MM X 1Mtr =475m
G.I. THREADED ROD 8MM X 1Mtr =1250m
RAWL BOLT M10(BOLT TYPE) =650 pieces
RAWL BOLT M8 (BOLT TYPE =1250 pieces
FEMALE ANCHOR 8MM =1400 pieces
G.I.NUT 10MM =5350 pieces
G.I.NUT 8MM =2000 pieces
MUPRO CLAMP 52MM =1375 pieces
MUPRO CLAMP 67 MM =315 pieces
SCREEN CABLE 2 CORE X 1MM =2950 meters
CABLE 3CORE X1.5MM =2950 meters
有些地方不大看得明白,內行一看估計就懂,誰能做說一聲!
發表于 2014-8-12 11:42:32 | 只看該作者
感覺是螺栓插銷等,有圖嗎?
GMT+8, 2026-5-27 13:41 , Processed in 1.115312 second(s), 19 queries .
