查看: 3476|回復: 7
New features in Laminate Tools version 4.1
發表于 2011-2-22 09:18:02 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
New features in Laminate Tools version 4.1  (first release, since launch of version 4.0)
Geometry
•    enabled the import of 3D curves from CAD, and other geometric entities for future enhancements
•    implemented new embedded SolidWorks interface, for easy ply definition
Design
•    enabled ply Split (dart) definitions as curves unrelated to the mesh, for easier generation of accurate flat ply patterns
•    added method of area picking bounded by an imported Boundary curve
•    added method of area picking by similar element normal orientation
•    enhanced the area picking method by visible element set
•    added support for import/export of element sets in Session files
Manufacturing
•    enabled Boundary curve definitions for easy and accurate flat ply outline pattern generation (incl. cutouts)
•    easy ply drop-off flat patterns now possible via imported boundary curves
•    added ply name to flat pattern DXF file, as a new pattern export option
•    introduced option to control the default exported IGES file extension name, for improved compatibility
Analysis
•    enhanced the Nastran export "merge" feature, to scan the mesh and property ids for best merged results
•    added support for the new Ansys element shell type 281
•    enabled Ansys properties export including global ply definition (zero thickness at drop-off)
•    added Laminate Tools material names to Nastran export files, for easier identification and re-use
Post-processing
•    Enabled basic output of generated failure results to the Altair HyperWorks H3D format, with further enhancements under way
User Interface
•    implemented COM Server Automation functionality, for remote control via custom client applications
•    enabled user-selected licence at launch, useful for multi-licence sites
•    several bugs corrected, and processing improved
PlyMatch
•    software updates in line with PlyMatch 2010 system upgrade, communication with the hardware re-engineered
•    enhanced error reporting, to troubleshoot operations
•    recording timer shows permanently during recording, and is stamped in the recording
•    increased best recording quality to 15 frames per second
•    available probe files now appear automatically in selection boxes
•    relaxed tolerance of camera movement, for smoother animation
•    relaxed default calibration tolerance for easier setup
www.caefinder.com
 樓主| 發表于 2011-3-10 13:58:33 | 只看該作者
下料的方法
PlyMatch_info.pdf
476 KB, 下載次數: 248
發表于 2011-3-10 21:36:04 | 只看該作者
發現自己英文不是很好
發表于 2011-3-10 22:48:46 | 只看該作者
下了,謝謝
 樓主| 發表于 2011-3-16 10:42:10 | 只看該作者
還是上個中文翻譯
PlyMatch.doc
25 KB, 下載次數: 239
發表于 2011-3-17 16:56:40 | 只看該作者
還行   支持下 [s:1]
發表于 2011-3-17 22:39:36 | 只看該作者
支持一下
發表于 2011-3-19 00:21:03 | 只看該作者
原來自己中文也不好!
哈哈 幫頂! [s:1]
GMT+8, 2026-5-28 07:16 , Processed in 1.168971 second(s), 22 queries .
