查看: 7736|回復(fù): 2
2010 Scott Plasma 10 Triathlon Bike
發(fā)表于 2010-3-19 10:17:38 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
http://hi.baidu.com/peng2006332/blog/item/fe687eb2e0d173acd8335a5f.html
Scott Plasma 10 Triathlon Bike:
When Scott sets a goal they achieve it. When they set out to make the first sub 1000g frame they made it. When they ventured into triathlon they brought to the plate the Scott CR1 Plasma. It featured elegant curves, a slippery profile, and featured Scott's proprietary CR1 technology making it the lightest TT frameset on the market. To be honest how do you improve on a bike that rides buttery smooth, corners like a dream, is light as a feather, and slips through air? This was Scott's goal and in that fashion they achieved it with the Scott Plasma 2 frame.
At first glance the Scott Plasma 2 triathlon bike sucks you in. The white paint on the top tube guides your eyes toward the integrated seat mast and makes the bike look lean and mean. However the beauty is in the technology that makes this the fastest triathlon bike in the world. Our goal at Trisports.com is to guide you through the key fundamental areas in the design of the Plasma 2 frame to help illustrate that when it comes to getting to the T2 first there is no parallel.
Everything on this bike is designed for optimum aerodynamics while keeping the frame extremely light. In addition the frame needed to be as compliant as its predecessor the CR1 Plasma frame. Scott has created the Plasma 2 frame using their proprietary IMP5 technology which uses a bladderless mold that combines the headtube, downtube, and seattube into one piece. The rear triangle is then attached seperately. This eliminates the need for "joints" dramatically drops the overall weight while improving stiffness and compliance throughout the frame. To this day Scott is the only company able to accomplish this feat and continues to keep this under wraps for fear of other manufacturers mimicing their design.
file:///C:/Documents%20and%20Settings/Administrator/Local%
The integrated seat mast further reduces weight and is possibly one of the best additions on any bike! Once you ride on an integrated seat mast your opinion is changed forever! It is more compliant. It is stiffer. It makes the bike corner better. Effectively you have a longer carbon downtube dissipating vibrations while helping transfer power into forward motion.
Another benefit of the CR1 Plasma and Plasma 2 frames are its adjustable seat angle through the seatpost clamp. The bike comes set up with a 76 degree seat angle, but flip the seat clamp hardware and you get an extra centimeter of forward adjustment and a 78 degree seat angle!
We turn our attention to aerodynamics. Some of the key features of the Plasma 2 frame is hidden at first glance. Only after looking from the front to the back do you realize the aerodynamic story Scott is telling us. Just look at the headtube, which is pictured to your left. It is has been designed to channel airflow around the front of the frame, thus improving aerodynamics.
Moving back on the bike toward the bottom bracket Scott has a truly unique design called the Speedskeg™. Scott has done two key things with this design. First the oversized the bottom bracket greatly increases the stiffness in the frame. Secondly Scott created a longer rear wheel fairing which was found to improve aerodynamics more so than if they placed the rear brake in this area. In contrast to their competition the rear brake is placed in a location that stays hidden by the seat stays of the bike.
Lastly, Scott kept the TwinTurbo™ chain stays parallel to the ground. This further opens the rear wheel fairing and guides the exiting air flow away from the axle. The horizontal dropouts allows you to get your rear wheel as flush against the fairing as possible for optimum aerodynamics.
Features/Benefits:
Internal cable routing
Speedskeg™: Oversized bottom bracket, longer rear wheel fairing
TwinTurbo™: guides airflow away from the axle
Carbon integrated steerer tube
Includes cutting tool for seat mast and Ritchy seat clamp which offers 30mm of adjustment
IMP5 carbon technology
Shimano Dura Ace 7900 20 speed, Profile O-Zero and Cobra aerobars, Profile Hammer OS, Shimano WH-RS10.
Fizik Arione TRI 2 saddle
18.94 lbs. Build Kit Specifications
Groupset Shimano Dura Ace 7900
Front Derailleur Shimano Dura Ace Braze-on
Rear Derailleur Shimano Dura Ace
Shifters Shimano Dura Ace bar end
Crank Shimano Dura Ace, 53x39 T
Bottom Bracket Shimano Dura Ace
Cassette Shimano Ultegra 12-25 T
Chain Shimano Ultegra
Brakes Shimano Dura Ace
Levers Profile Design QS2
General Specs
Frame Scott Plasma2, IMP5 technology / HMX net
Fork Scott Carbon Plasma 2 1-1/8" carbon steerer integrated
Headset Ritchey WCS Carbon integrated 45 mm drop-in headset
Basebar Profile Design O-Zero
Aerobar Profile Design T2 Cobra Carbon
Stem Profile Hammer OS
Seat Post Integrated
Seat Post Clamp Adjustable Ritchey WCS Aero
Saddle Fizik Arione TRI 2
Pedals N/A
WHEELSET
Wheelset Shimano WH-RS10 black, 16 Front / 20 Rear
Tires Continental Triathlon 700x23c
Want to spec your bike differently? Give us a call at 1-888-293-3934!
Components are subject to substitution based on availability, if this occurs parts of equal or greater value will be substituted
Size (cm) (F) (A) (B) (C) (D) (E) (G) (H) (I)
Frame size (cm) Head Tube Angle Head Tube Length (mm) Effective Top Tube Length (cm) Seat Tube Angle BB Center to top of seat tube (cm) Chainstay Length (cm) BB offset (cm) Standover Height (cm) Stem Length (mm) Wheel Size
XXS/47 46.5 71 90 49.5 76 64.0 40.6 -7.0 72 80 700
XS/49 47.6 71.5 100 50.5 76 68.0 40.6 -7.0 73.9 90 700
SM/52 48.8 72 110 52 76 72 40.6 -7 75.9 90 700
MD/54 49.9 72.5 120 53.5 76 76 40.6 -7 77.9 110 700
LG/56 51.9 72.5 120 55.2 76 80 40.6 -7 79.8 110 700
發(fā)表于 2010-3-19 18:27:54 | 只看該作者
好資料
發(fā)表于 2010-4-28 19:04:06 | 只看該作者
frpbbs
對ENG事文盲啊,麻煩好心人翻譯成中文了
,不盛感激
