查看: 3161|回復(fù): 0
2010 Automotive Interior & Exterior Products and New Materials Applicatio
發(fā)表于 2009-11-4 13:28:04 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
•    The largest scale Science Discussion Conference about Interior & Exterior Products Development......
2010 Automotive Interior & Exterior Products and New Materials Application Seminar
Date:May.28-29.2010                         Add:Shanghai, China (Pending)
Support: SAE-China
Cooperate: Interior & Exterior Decoration Technical Committee, Chery Automobile Co., Ltd
Organizers:Shanghai Youshi Business Consulting Co., Ltd
            Chinese Automotive Conference Net
Executive:  Jia Ding Youshi Exhibition Service Center
Section Forums
2010 Automotive Rubber and Plastic Technology Development and Application Seminar
The 2nd Automotive Body Design and New Material Application Seminar
2010 Automotive Plastic Products Design and Development and Manufacturing Technology Conference
Compounded Materials and High-Performance Materials Application Seminar in Automotive Industry
1、Summarize
Along with the more higher of Chinese auto position in the world, Chinese consumable market had been changed into more wisdom from the original trend to automotive brand, This change will strengthen the integrated ability of automotive products and make automotive sculpt and structure and engineering requirement more mature, Which will create more opportunity and developing space for self-brand of China.
Detail decide the success or failure. How to let the interior & exterior not only be an element but also be your sales lighten point and product lighten point, This is our facing problem in automobile industry. We will talk about the interior & exterior parts` R&D and manufacture and its related topics, For example the refinement of decoration、athletics design、dynamics analysis for damper and so on, They will have a great effect on the quality of elements and the development of module and application of new materials, Maybe you can find some solution or idea through our this conference.
Automotive Interior & Exterior Products industry is a field with high-speed development and take a very important position in the whole automotive industry. Many companies complained that they need a professional platform to reflect the status of this field and find out the future developing trend. Today, With the great participation and support of those experts from this field, We careful and conscientious release this communication platform for the technology and design and products and marketing and process and materials about Interior & Exterior. We expect your activity to take part in and share your experience.
In order to proceed the communication and cooperate, We aborative to organize this seminar. The first day is the primary conference time, Our guests will active based on three sections which include the whole-vehicle and R&D institutes and components manufacturers; The second day will discussion for per section and visit. The former conference held in Wu Hu got many support from SAE-China and Chery Group, More than four hundred fifty person from three hundred companies attended this conference and gave a high praise.
2、Exhibition Scope
(Including interior systems, safety systems, seats systems, electronic systems, exterior systems, materials systems and so on)
Automotive bumper、chair、panel Assembly、steering wheel and its jacket、dynamo、mould and plastic module、inside cover (door interior decoration、top interior decoration、column interior decoration、side interior decoration etc…) 、Polyammonia ester materials、normal materials (plastic ABS、modified PP、leather、flock、foam、glass steel、engineering plastic、composite materials etc…)、special materials、interior & exterior design solution(clay model、data model and model mold sample)、automotive carpet (fast foot)、sunproof and decoration、hub cover、carbody decoration、fur veins、process(injection molding、slush、vacuum suction plastic、blow molding、PU foam、compressing heat、envelop、spray、plating、weld etc…)、interior decoration security and green developing technique、tester、decoration color、volatile treatment technique、gasoline tank、rapid prototypes making technique、orientation and fasteners system and other involved systems.
3、Paper collects and published
We will invite some top designers and process or materials experts to share their opinions and the latest progress for interior & exterior products in the quick-growing automotive industry. Now, Any papers with high-quality or with connotation and novelty will be collected then published in national formal publications.
Topics will around:
New    materials applied in automotive industry
New process or technical development trend of automotive plastic and froth products
Design about gain the high-performance or high-quality or excellent equipments and cost-saving
   Advanced process and module technology
Quick molding,     analysis and testing
Integration and modularization design
   Decoration and assemble
failure analysis and prevention
   Environment protection for plastic and froth
Jointing and adhibit and finishing for plastic
Adhibit and finishing for froth
Bond and liner and seal
   liner and seal
Appearance and color
   Design and manufacture for mould
Restraint system design
   Law or rules for head collision and Child seats safety
Design     for Restraint system and passengers protection
Rheology application
Paper abstract must be released before Feb.28.2010 at latest
The final paper should be released before April.30.2010 at latest
The final speech should be released before May.15.2010 at latest
Paper requirement
(1) Abstract must include one of above mentioned topics, simple but clear, as the soul of paper;
(2) Abstract will be limited into 150-200 words and the key technology can benefit attendees;
(3) Paper should be with exact data and smooth letter but limited within six thousand works;
(4) Please save your file with .doc and A4 standard file form, the margin for every side must be left 30mm and don`t keep the print page in the file;
(5) List clearly your refer literatures and the first author instruction and contact information after the text;
(6) Paper must be written by yourself and without any commercial use, Any articles with sales trend will be rejected;
Abstract review and approved process:
A professional team constructed by the seniors technical engineers will review your paper abstract based on attached standard:
  ● Topic accord with the current trend
  ● Own the practicality value and advanced opinions
  ● Instruct and guidance for work of attendees
Any accepted paper abstract will be notify to the author for your go ahead and we will delivery the file form to you
How to delivery your paper:
Papers abstract can be sent to e-mail address ejohn@online.sh.cn and call us for confirmation if received or
not, Further questions, Please contact with the organizers.
4、Content and Charge(Registration deadline: May.19.2010)
  A   Registration Fee: RMB1,900 per head, Including conference materials & lunch & tea break & visit, RMB1,500 per head if you payoff before Jan.31.2010, RMB2,500 per head for whose register out of deadline ;
B. Show`s charge
RMB4,800/2M2 (Only one display table w/h two chairs);
RMB9,800/9 M2 (Professional setup, VIP booth);
10% additional charge if you choose the booth places
Organizers will arrange the order of the seats based on the registration and payoff`s order due to many attendees and guests.
First come first serve
Please delivery your detail information to us for our post the invitation on time.
Bank information:
Company Name:  Jia Ding Youshi Exhibition Service Center
Account Number: 32451008080028808
Bank Name:Cheng Qiao Branch, Shanghai Country Commercial Bank
Shanghai YouShi Business Consulting Co., Ltd was founded in 2001, We are a modern and professional service company who worked on organizing seminar, forum, games and talent recruiting and other kinds of international conference in automotive field. Our activities concerns with automotive design, R & D, manufacture, HR, procurement, sales, maintenance, service and other related departments. There are more than 120,000 attendees from almost all famous brand automobile companies or groups to join in our activities. Now, We owned about eight hundred team memberships and two hundred sixty thousand database related with automotive industry. We can support to create and expand your value anytime.
We expect your participation! As a professional conference with high-value technique and plenty sources, More guests and professional speech are being invited now. Welcome your join in us and give us any advice or commends! You will enjoy this wonderful event with us together!
Contact with
Mr John Deng(Cell phone# 13801949747)
Tel:86(21) 33518744,33518477            Fax:86(21) 6290 4313
E-mail:ejohn@online.sh.cn
Website: http://www.made.com.cn
Former Lecturers (No order in list)
Liu Neng Quan    Director of Interior& Exterior Dept, Technical center of SAIC Group
Cao Du           Director and chief of engineer, Interior& Exterior technical committee of Chery Group
Zhou Jian Jun    Supervisor engineer of Interior dept and project manager of project management dept, Shanghai Launch Technical Automotive Center
Song Dao Gui      Manager of Interior& Exterior dept, Shanghai Engineering Institute of Changan Group
Chen Qing Dong   Vice director of Interior& Exterior technical committee, Chery Group
Jiang Mei         Secretary-general of automotive non-metal material branch, SAE-China
He Li Ping        Professor of Automotive body advanced design and manufacture National Key Laboratory(Hu Nan University)
Ren Qi Long       Super-chief of engineer, Futian Auto
Li Xiao Lei        Director of software development dept, DaikyoNishikawa (Shanghai) Software Technologies Co., Ltd
Li Zhong Bing     Minister of material dept and Director of automotive engineering institute materials technical committee, Chery Group
Tang Rui Lin      Vice chief of engineer, Faw Haima Motor Co., Ltd
Ge Yue           Marketing manager of China, QPC
Chen Shi Ping     Technical manager of Asia-Pacific Area, Basel
Liu Jun           Johnson Controls, Inc.
Li Yong Hua       Engineer of KINGFA SCI.&TECH. Co., Ltd
Wang Wei Guang   Interior &Exterior Dept, Technical center of SAIC Motor Company
Xin Min Qi        Shanghai Kumhosunny
Li Luo Xing       Professor of Material and engineering academy, Hu Nan University
Li Wu Fan        Shanghai SICAR Vehicle Technology Development Co., Ltd.
Ma Zhen Hua     General manager of China, Creaform Shanghai Ltd.
Jin Sun           Professor and vice director of Shanghai digital automotive body engineering key laboratory
Shen Jian Dong   Body and Exterior Director, Pan Asia Technical Automotive Center Co., Ltd
Lu Pei Ji         Product consulting director of Leeport & Co.
Zhu Wen Ye      General manager of Wuxi city, China Auto Logistics Equipment Factory, Yongda Group
Hu Zheng Nan    Technical Director of Shanghai Launch Technical Automotive Center
Xu Ji Guang      Director of Technical centre, Jiangsu Baihe Coating Co., Ltd
Zhou Guang Ya   Technical director of Shan Dong Zou Ping Automobile Material Co., Ltd
Tang Zhi Feng    Manager of Body dept, Magna Steyr China
Lei Yu Cheng     Chairman of the board and CEO, TJ INNOVA Engineering & Technology Co,. Ltd
Zhou Ming       Sales manager of ASI DataMyte (Shanghai) Trading Co., Ltd
Wang Yan Wen   Vice general manager of Shanghai SICAR Vehicle Technology Development Co., Ltd.
Nie Chun        General manager of DaikyoNishikawa (Shanghai) Software Technologies Co., Ltd
Wang Hui        Technical director of Asia-Pacific Area, Germany Benteler Automotive Industrial Company
Dong Hai Lin     Marketing director of CCA Company
Yang Yang       Sales manager of China, Geomagic
Tian Ya Mei      General manager of China Auto Parts & Accessories Corp./China Auto parts Plastic Developing Centre
Zhang Tao      Vice president of Shanghai SICAR Vehicle Technology Development Co., Ltd.
Chen Min Jun   General manager of Shanghai branch of Haitian Group
Tao Yong Hua   General manager of Zhe Jiang Tao Shi Mould Group
Lu Yu Liang     Senior engineer and manager of Design Dept in Technical centre, Ningbo Xin Tai Machinery Co., Ltd
Zhang Feng     Manager of Design and Sculpt Dept in Technical Centre, Yanfeng Visteon
Feng Bing      Technical vice president of Suzhou Wanda Automobile Interior Decoration Factory
Zhang Bin      Vice president of PUSH Die & Mold Co., Ltd, Yibin Push Group Co.,Ltd.
Wang Qing Guo   Senior engineer and director of Non-metal branch dept of technical centre, FAW
Qian Zhou Zhong  Technical director, Jiangyin Mould Plastic Group
Xie Xian Hua      Developing manager, Ningbo Inoac Huaxiang Automobile Products Co., Ltd
Cui Chun Lin      Sales manager of Hanwha Shanghai
Zhang Jun Hua   Manager of Chemical and engineering section of Material dept, Automotive engineering institute, Chery Group
Zhou Zhao Feng   Sales Developing Manager of China, Henkel
Zhang Shu Li     Technical Centre of SAIC Group
Shen Qi Zhong    Xinyi Automobil Components (Wuhu) Ltd.
Pang Jing         Autoliv, Shanghai Vehicle Safety Syst. Co. Ltd
Tu Shao Ping      Chery Group
Fang Gen Ming    Passengers Vehicle Company, of SAIC Group
Zhang Da Wei     Shanghai SICAR Vehicle Technology Development Co., Ltd.
Wang Guo Ling    Sales developing director of Shun Pu Company
Xia Yong        Automotive Engineering Academy of Tsing Hua University, Automobile Safety and Energy-saving State Key Laboratory
Zhou Jia         Materials and Engineering Academy, Hu Nan University
Shi Rong Bo     Manager of Non-metal branch, Material dept of Automotive Research Institute, Chery Group
Luo Ming Hua    R&D engineer of Shanghai Kumhosunny Plastic Co., Ltd
Shan Xiao Ying   R&D Manager of Polyurethane Automobile Centre, BASF Asia-Pacific Area
Zhang Ying      Manager of Application and Development Dept, Shanghai PRET Composites Co., Ltd.
Wu Sheng Jun   Director, Plastic field of Non-Metal Section dept, Material dept of Automotive Research Institute, Chery Group
Chen Wei        Passengers Vehicle Company, of SAIC Group
Zhang Heng      China Chief of representative, America Q-Lab company
Fei Shi Lin        Assistant of sales manager, Industrial Products of East-China area, X-Rite
Vincent Nijzink,  General manager in China, EAS  Europe  B.V.
Fred Fischer,    Product manager of Stratasys U.S.A
Todd Fortner,    CEO of Chang Shu Interior company
Dr. Karsten Brast,Vice president, Project and Engineering Director, SAS Automotive Systems Co., Ltd
Frans Vandenbosch   Foreign expert specially hired by TJ INNOVA, High management for Interior in famous International group
Michael Crewdson   America Q-Lab Company
Dhiraj Uikey        Shun Pu Group
Roland.van.Giesen  Global Marketing Technology Manager of STAMAX
Rolf Balte          Asia Acoustics Director of HP Pelzer Automotive Interior Systems (Taicang) Co.,Ltd.
•  Item url:http://www.made.com.cn/english/2009/0901/content_34.htm
