查看: 5939|回復: 13
葉片損傷的聲學探測--古老的方法的現代升級版
發表于 2009-4-27 21:32:21 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
Damage Detection in Wind Turbine Blades using two
Different Acoustic Techniques
Abstract
Facing the climate change the use of renewable energies gains in importance. Especially the wind
energy branch grows very fast. Bigger and more powerful wind mills will be built in the next
decades and the safety of the mills will play a major role. Wind turbines are treated as buildings
and therefore have to be inspected at regular intervals. Especially the turbine blades are highly
stressed during operation and a blade breakdown can cause a big economic damage.
The turbine blades consist of glass fiber reinforced plastics (GFRP) and sandwich areas
containing wood or plastic foam. The blades are manufactured as two halves and glued together
afterwards. Typical damages are delaminations within the GFRP or the sandwich and missing
adhesive or deficient bond at the bonding surfaces.
The regular inspections of wind turbine blades are done manually by experts and are limited
to visual appraisals and simple tapping tests. To improve the safety of wind turbine blades nondestructive
testing techniques using acoustic waves are being developed.
To detect delaminations within the laminates of the turbine blade a local resonance
spectroscopy is used. A small hammer is used to tap onto the blade and the excited sound is
recorded using a microphone. A structural change within the material is displayed in a change of
the frequency content. Furthermore the exciting signal is recorded and gives additional
information about the structural health of the wind turbine blade.
To detect missing or kissing bond areas from the outside of the blade the impulse-echotechnique
is used. An ultrasonic pulse is sent into the material and is reflected at flaws or material
boundaries. This pulse has to be strong because the GFRP are highly damping. It is difficult to
see through several centimeters of GFRP and the choice of the ideal transducer is very important.
To inspect bonding areas from outside the blade will be a great advance in wind turbine safety.
Damage Detection in Wind Turbine Blades using two.pdf
623 KB, 下載次數: 301
發表于 2009-7-12 16:00:13 | 只看該作者
行波震蕩在葉片探傷上的應用
 樓主| 發表于 2009-7-12 16:05:38 | 只看該作者
一百多萬,買吧。
好東西。
尤其是有些有那個明顯膠粘劑施工暴力美學更加需要了。。。。。。。 [s:4]
發表于 2009-7-12 16:17:52 | 只看該作者
沒有錢5555
 樓主| 發表于 2009-7-12 16:35:09 | 只看該作者
搞鋪層系統有錢,搞UT沒錢?
你們鋪層系統,你們老大組織搞得?
發表于 2009-7-12 16:49:47 | 只看該作者
UT自然有傳統方法代替
鋪層系統我們自己搞的
這個要有前瞻性的
 樓主| 發表于 2009-7-13 21:44:05 | 只看該作者
呵呵,可以貼出來看看否?
發表于 2009-7-14 08:20:55 | 只看該作者
還是不貼了吧
這個涉及的太敏感了
發表于 2009-7-14 09:14:45 | 只看該作者
頂一個 [s:1]
 樓主| 發表于 2009-7-14 12:51:46 | 只看該作者
引用第7樓ktking于2009-07-14 08:20 AM發表的  :
還是不貼了吧
這個涉及的太敏感了
敏感個啥?
那么多細節沒有, 只要你做的好,別人模仿都難,是吧。
獻圖, 讓兄弟們瞅瞅。[s:4]
GMT+8, 2026-5-27 13:40 , Processed in 1.164716 second(s), 22 queries .
