查看: 3150|回復: 0
風電葉片做超聲--NDT
發表于 2009-4-27 21:24:12 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
Ultrasonic NDT of wind turbine blades using guided waves
Abstract
In order fully to exploit energy of wind power the construction elements of the wind turbine should be inspected periodically.
Ultrasonic air-coupled technique using guided waves has been selected for inspection of wind turbine blades, because only one side
access is enough and no contact is needed. Dispersion curves of phase velocities as well as leakage losses versus frequency were
calculated using numerical global matrix model.
Taking into account the results of the performed simulations the frequency of the ultrasonic transducers was selected to be 290
kHz due to non-dispersive region of phase velocities. The ultrasonic air-coupled technique using guided waves was used for
investigation of the artificial internal defects in the wind turbine blade. These defects (diameter 19 mm and 49 mm) were made on the
internal side of the main spar. From the ultrasonically obtained images it is possible to recognise the geometry of defects and to estimate
approximate dimensions of the defects.
Ultrasonic NDT of wind turbine blades using guided waves.pdf
669 KB, 下載次數: 260
GMT+8, 2026-5-28 03:39 , Processed in 1.130847 second(s), 22 queries .
