查看: 6436|回復: 4
耐高溫,高結合度膠衣
發表于 2004-5-14 14:29:12 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
     Is there any high solid,temperature,sanding gelcoat in China?The steel mold's temperature is near 90 Dgr.C,what company can afford the proper gelcoat for this production?
發表于 2004-5-18 15:40:19 | 只看該作者
Ok,you can enquiry Mr.Shun, his mobile is: 013813930023. Maybe he can help!
發表于 2004-5-19 12:57:59 | 只看該作者
Jinling DSM have this type of sanding gelcoat,you can contact with Mr.Xie about more detail information(025-85570570-3306)
發表于 2004-6-8 14:25:21 | 只看該作者
The gel coat you want, we have it(high quality):<br>The gel coat is A400TV-S-xxxx <br>HDT:  95 °C<br>Barcol hardness: 45<br>good sanding <br>no air bladder<br>Application: Auto parts ,etc.,<br>Other :<br>We have Fire-retardant gel caot: A400TV-F-xxxx<br>low smoke density, high LOI ,high HDT, good weatherbility, <br>Application:train parts, Auto and boat parts, building <br>you can contact: 025-85570570-3108<br>Best regard! <br>
發表于 2004-11-29 19:25:41 | 只看該作者
采用乙烯基類膠衣
GMT+8, 2026-5-26 03:05 , Processed in 1.117414 second(s), 20 queries .
