樓主: wangqin1010
專業(yè)生產(chǎn)SMC,BMC模塑料,強(qiáng)大的技術(shù)團(tuán)隊(duì)支持
21#
 樓主| 發(fā)表于 2009-5-15 10:12:28 | 只看該作者
做人要勤勞。up~
22#
 樓主| 發(fā)表于 2009-5-22 08:59:57 | 只看該作者
技術(shù)服務(wù):
本公司與國內(nèi)多家權(quán)威機(jī)構(gòu)合作,加上公司自身一流的技術(shù)人員,可為客戶提供:
前期SMC、BMC產(chǎn)品的開發(fā)
SMC、BMC成型技術(shù)支持
SMC、BMC成品的前期技術(shù)開發(fā)
復(fù)合材料一體化解決方案
23#
 樓主| 發(fā)表于 2009-6-1 09:17:55 | 只看該作者
Shanghai FRP composite materials Cayman Ltd. which located in the Nanxiang high-tech district of Jiading district, Shanghai, is a high-tech company with development and production of composite material as a whole. This company is specialing in the production of SMC, BMC- Bulk molding compound, which have passed the quality system certification ISO9001,2000. The company's employee reaches 60 persons, and its total sale exceeds fifty millions Yuan.
Company owns two advanced large scale production lines. Perfect technical monitoring and detection equipment, as well as solid technical strength and technical research and development ability may offer the unifinication solution of composite material for customer. The SMC, BMC , whose productivity has reached ten thousands tons or above per year, and its qualities have reached domestic and international advanced level.
Our concept: It is professional where quality orginates
24#
 樓主| 發(fā)表于 2009-6-12 08:48:28 | 只看該作者
Industrial introduction
Ⅰ.Brife introduction of SMC
SMC is the short form of “sheet moulding compound”. This is a raw material for mold pressing. The core is chopped strand and unsaturated polyester resins paste that are covered by LDPE & HDPE sheet. It is 3mm-6mm thick , 600mm-1200mm wide and packing in rolls or boxes. When using , be sure to cut , weigh , uncover film, and join in the heat up mould, after adding high presure and preserve a time, then you can take off membrane to get the product.
Ⅱ.Application of SMC
1. Apply to the auto industrial:
Developed country such as Europ, America and Japan have adpoted SMC in the auto-making, including car, train, tractor and motorcycle,ect. Major application parts include following kinds:
?· Suspension element, around bumper and appearance plate
?· Auto body and the parts of auto body, the housing of auto body, hard shell roof, floor and door, radiator protects railings board, front board, step, luggage storehouse blind flange and sunshade are sought , wing son board, engine cover, lamp reflector.
?· Engine cover parts, such as air-condition ware shell and wind scooper, air inlet duct covers , Dao Pian encloses fan, heater blind flange, the parts of water tank, braking system Tong parts, as well as the bracket of storage battery, engine acoustic septum.
?· Vehicle decoration parts, the door board of interior trim, door handle, instrument plate turns to bar parts, mirror frame and seat.
?· The parts of electrical equipment such as pump cover, the drives such as gear acoustic septum systematic element. In which, especially the bumper, roof, former face parts, engine cover, engine acoustic septum and around wing board are most important. Their output is the biggest.
2. The utilization in railway are mainly vehicle, include train window frame, toilet assembly, seat, the table top of tea table, carriage wall and roof sheet .
3. The application in architectural project
?· Water tank
?· Bathe appliance, major product are bath jar, bathe , wash pool and waterproof a plate of, convenient ware, put on makeup Taiwan, especially bath big jar, overall bathroom equipment etc.
?· Construct shuttering between
?· Store component
4. The utilization in the industrial and communication project of electrical equipment
?· The case of electrical equipment: The switch box of electrical equipment, the wiring box of electrical equipment and appearance plate.
?· The generator parts and script of electrical equipment: Such as insulator, insulation operating tool and the fan housing of electrical equipment.
?· Electronic project is applied: The board of printed circuit of electronic machine
?· Communication equipment is applied: Telephone pavilion and wire cable distribution case
5. In other fields:
?· Seat, , and and food utensil if washing vegetable pool, microwave tableware, bowl and dish, the rubber packing sheets such as plate
?· Container
?· Pole chuck
?· Tool hammer handle shovel handle
?· Food utensil such as washing vegetable pool, microwave tableware, bowl and dish, the rubber packing sheets such as plate
Ⅲ.The influence of SMC to environment
It is proved that this project do not have obvious problem of environmental pollution,since the SMC encloses intactly, and few styrene gases are discharged. Accroding to the national standard (TJ36-79), in workshop, the styrene density must be lower than 40mg/m3, and this project is totally accord with international stipulation. Waste gas may convulsions emission. It do not have the problem of sewage disposal since the the water is no need in the production process. Besides, the production makes little noise.
Therefore: SMC is the environment-friendly material of 21 century
25#
 樓主| 發(fā)表于 2009-6-22 10:10:23 | 只看該作者
生意不好做。頂貼靠自己~~ [s:4]
26#
發(fā)表于 2009-6-22 10:47:26 | 只看該作者
呵呵,同行,同感。
27#
 樓主| 發(fā)表于 2009-6-24 08:29:34 | 只看該作者
SUPPORT OF TECHNOLOGYur company cooperated with most of authority in the domestic,and have FRIST-CLASS technical,so we can supply with client:
· the first peroide development of SMC、BMC
· a formed technical support of SMC、BMC
· the first peride development of manufactured SMC、BMC
· solution to composite material integration
28#
發(fā)表于 2009-6-24 10:12:00 | 只看該作者
我也來支持一下。。。嘿嘿。。。上次去過的哦。。。嘎嘎~加油~
29#
 樓主| 發(fā)表于 2009-6-26 11:08:42 | 只看該作者
恩。謝謝!
30#
 樓主| 發(fā)表于 2009-7-10 14:47:02 | 只看該作者
Company owns two advanced large scale production lines. Perfect technical monitoring and detection equipment, as well as solid technical strength and technical research and development ability may offer the unifinication solution of composite material for customer. The SMC, BMC , whose productivity has reached ten thousands tons or above per year, and its qualities have reached domestic and international advanced le...
