(</B>固化系統(</B>Curing System</B>):</B><p></p></B></P>FUCHEM系列乙烯基酯樹脂一般為非預促進樹脂,固化系統與通用不飽和樹脂類似,在室溫或90℃以下固化時,應該加入固化劑和促進劑,但因根據成型工藝、作業溫度、制品厚度、濕度大小等調整相應的加入量,同時根據不同的情況選用不同類型的固化系統。(The basic range of FUCHEM VER are unpromoted and required the addition of both accelerators and promoters just like general UPR. The selection criteria of the curing system and amounts depend on the desired gel time, the temperature of both the resin and workshop, the laminate thickness, humidity, impurities and the posting-curing possibilities.))</P><p> </p></B></P>低溫固化</B>(Low Temp Curing)</B>:</B><p></p></B></P>當制品必須在10℃以下固化時(如:室外粘接與修補,防腐蝕內襯等),下面的系統可用于0-10℃,也可用釩類促進劑。(If to be handled below 10℃, for example outdoors adhesion or anti-corrosion lining, the below curing system is recommended.)<p></p></P>MEKP/AAP<p></p></P>Cobalt-6%<p></p></P>DMA-100%<p></p></P>2.0-2.5%<p></p></P>7-10%<p></p></P>0.1-0.6%<p></p></P><p> </p></B></P>室溫固化</B>(RT Curing)</B>:</B><p></p></B></P>MEKP</B>系統</B>(MEKP Curing System)</B>:</B><p></p></B></P>為常用固化系統,使用時加速劑、促進劑及固化劑必須分別加入,且每加一種時,都必須充分混合均勻,方可加入第二種,添加順序為:加速劑→促進劑→固化劑。當要求膠凝時間和固化時間較快或固化薄層制品時,可以用過氧化乙酰丙 酮(AAP)取代MEKP;另外適量的DMA加入可以獲得良好的固化效果。(This system is frequent used, and it is important to mix these additives into the resin as follows: first the Cobalt Naphthalene(CoNAP) or Cobalt Octoate(CoOCT) or Dimethyl Aniline(DMA) and then Methyl Ethyl Ketone(MEKP), also thorough mixing is necessary to get optimum results. In case of thick laminating or short gel time required, AAP is a good accelerator instead of MEKP, meanwhile some DMA is recommended to ensure optimum curing.)<p></p></P>MEKP-55%<p></p></P>Cobalt-6%<p></p></P>DMA-100%<p></p></P>0.9-2.5%<p></p></P>0.2-0.5%<p></p></P>0.0-0.2%<p></p></P><p> </p></P>BPO</B>系統</B>(BPO Curing System)</B>:</B><p></p></B></P>該系統可以獲得較好的固化性能,比較適用于一些濕度相對較高的使用場合,另外也應用于一些MEKP/Co固化系統不適用的防腐蝕場合(如含次氯酸離子介質等)。(Benzoly Peroxide (BPO) curing system is also suitable for VER yielding better curing, quite ideal for high humidity cases, and this system shall replace MEKP system in some special case such as hypochlorite-contact fabrication.)</P>DMA-100%<p></p></B></P>BPO-98%<p></p></B></P>0.05-0.2%<p></p></B></P>1.0-2.0%<p></p></B></P><p> </p></B></P>中高溫固化</B>(Elevated Temp Curing)</B>:</B><p></p></B></P>適用于FUCHEM乙烯基酯樹脂的中高溫固化劑與通用UP相同,對于熱模壓或拉擠等工藝適合,常見的有BPO和叔丁基過苯甲酸酯(TBPB或1,1-二(過氧化叔丁基)-3,3,5-三甲基環已烷(DTBTC))系統,以獲的良好的固化效果和縮短固化時間;在高速拉擠工藝中,可加入適量的高活性過氧化碳酸酯。(BPO is commonly used yielding longer pot life, yet rapid curing is obtained at temp above 80℃. Combinations of different peroxides (such as TBPB or DTDTC) are recommended in order to obtain optimum properties and reduce curing time, these are suitable for pultrusion or thermal-molding. And some positive peresters are recommended in speed pultrusion.)<p></p></P><p> </p></B></P>低放熱峰系統</B>(Low Exotherm Curing)</B>:</B><p></p></B></P>在較厚鋪層結構或平板制作中,要求較低的放熱峰以控制最小的翹曲和防止分層,應推薦異丙苯過氧化氫系統(CuHP)系統,該系統也不產生氣泡,在RTM工藝中可推薦使用;若要求放熱峰值低于100℃,推薦使用CuHP和特丁基過氧化氫的混合物;另外錳鹽促進劑可產生較低的放熱峰。(In the production of thick laminates or wet-on-wet above 5mm, lower exothermic heat to avoid over-heating is necessary, which in turn could lead to delaminating, increased shrinkage and possible warping, Cume Hydroperoxide (CuHP) is recommended instead of others, on the other hand, CuHP does not create any foaming and specially recommended for RTM applications. When exothermic peak below 100℃ is necessary, Tertiary Butyl Hydroperoxide(TBPO)is maybe employed in combination with CuHP.)<p></p></P> <p></p></B></P>后固化(Post Curing)</B>:<p></p></B></P>為使FUCHEM高性能樹脂獲得最佳的耐熱性和耐腐蝕性,如接觸食品、強腐蝕性環境的FRP,后固化是十分必要的。推薦的后固化條件是90~100℃,3~6小時——對于厚制品和形狀比較復雜的制品,后固化時間需要更長。比較低的后固化溫度是沒有效果的,一般可以通過干熱空氣或加熱器進行加溫,同時可以用油布包覆以提高效果。但過高的溫度會導致脆裂,應防止局部過熱。在制品制作完畢后,后固化處理應盡快進行以提高效率。(The performance of composite can be enhanced by post curing the finished component at elevated temperatures, especially for these used in aggressive environments or for contact with food. For maximum effectiveness, post curing at 90-100℃ should be performed 3-6 hours as soon as possible after the composite has gelled and its exotherm has subsided. For large components, post curing should be practised as soon at the composite structure is completed. This post curing should be done with hot dry air or heater, yet hot spots should be avoided, a good technique for improving heating efficiency is to cover the post curing vessel or laminate with a tarpaulin.)</P><p> </p></P> |
