返回列表 發(fā)新帖
樓主: akacolin
真空導(dǎo)入新手求助
11#
發(fā)表于 2010-4-13 09:44:38 | 只看該作者
可以找我們天能公司呀, 我們提供全面的技術(shù)支持. 歡迎到我們這里參觀, 指導(dǎo).
我的電話: 15162680045 郭先生 [s:1]  [s:1]
12#
發(fā)表于 2010-4-13 10:02:15 | 只看該作者
Basically, SALT is a programming language that comes with a set of libraries for general purpose programming and modules that give it access to the internals of RTM-Worx. Those libraries, called the Application Programming Interface, or API for short, allow you to develop your own simulation tools, or even customize the calculation itself!
The possibilities are endless, here is a short list of examples:
•    Model based control (the goal in COMPROME);
•    Generate parametric models;
•    Implement dynamic boundary conditions: complex pressure or temperature boundary conditions at a gate, possibly controlled by 'virtual sensors', e.g. by checking the flow front, pressure in a specific spot or any other condition that may exist and adjusting the conditions at the inlets, vents, the mould temperature etc.
•    Automate a parameter study, calculate statistics in SALT;
•    Write a script to demonstrate your results in RTM-Worx. Add fancy zooming, panning, load several models and animate them individually etc.
•    Connect SALT to your injection machine.
This list is by definition not complete: someone will come up with some use for SALT that we never thought of. At least, that is the idea.
13#
發(fā)表于 2010-4-18 16:42:54 | 只看該作者
我好像幫過你了,所以我啥也不說,嘿嘿
14#
 樓主| 發(fā)表于 2010-4-21 16:44:07 | 只看該作者
沒人。。。。。。。
15#
發(fā)表于 2010-4-21 16:47:38 | 只看該作者
據(jù)我現(xiàn)在使用的一些材料設(shè)備 工藝等等
找個輔材的廠家都可以給你指導(dǎo)或搞定
12
返回列表 發(fā)新帖
